Cartwrights
I am working on a dual engine 87' 28' Chris Craft with MR drives. Installed new everything. Bellows, gimbal bearings, shift cables, controls and control cables, the works...... Everything is back together as it should be. I have done many of these jobs and never run into the issue I have run into here. OK, The control end of the cables are in the outer hole on the shift lever in the control. The new control is the exact same brand and model as the old one, so no change there. All of the cable ends are new, I even wire brushed the shift shaft before reinstalling it. At the shift bracket assembly, I adjusted the cable ends as they were supposed to have been adjusted. Here goes; If forward catches, reverse will not even grind it is so far out. Adjusted the other way, If reverse catches, forward will not even grind it is so far out. Adjusted dead center, Both forward and reverse grind and will not engage. It is as if the stroke is not long enough even though it is as long as it can possibly be. The clutch dogs looked good when I had the units apart. If I disconnect the shift cable from the shift bracket and pull and push the cable by hand it goes into forward and reverse just as it should. The control cable does not have a long enough stroke to engage the shift cable at its ends. How in the world can this be? The drives worked fine when it was pulled from its slip and parked in a hangar 4 years ago.
