R
Richard Mudarri
Guest
"My 94 350 Mercruiiser Magnum
"My 94 350 Mercruiiser Magnum runs great but sometimes stalls when shifting (frequently) and then will not restart until ? whenever it decides to? Recently I was told that the problem is probably with the interupter cable and that a stronger spring could solve the problem or replace the cable.
These problems began after the engine was out to replace the flywheel.
The boat is in storage - still shrink wrapped and unfortunately every place is buzy and can't look at it for a while. I want to use the boat now but I don't want to get stuck.
I would like to attempt to fix this myself. Is this a complicated job? Are there numerous possible issues? or could it be a simple spring or cable adjustment. How do I identify the shift interrupter cable, spring and switch? How would you determine which is causing the problem?
Thanks for any reply."
