Mercruiser Sea Pump Impeller Disintegrated
ehlien
The pump guts on the sea water pump on my 454 Mercruiser was dry rotted and disintegrated. When I replaced the impeller there was not much left. There were a couple bigger pieces and a lot of smaller debris but no way all the old impeller was inside the case. Will the junk all pass out or should I be looking for parts or possible blockage?
Its always something.... any suggestions for chunk hunting ..bearing in mind I'm not the lucky type!!>
Start immediately down stream from the pump, which in your case is apparently the ps cooler. If end caps are removable, remove them and shine a light thru the tubes. Should find most of the chunks on the inlet side of the cooler. If caps not removable, remove water lines and reverse flush it with a hose. That's the easy place to start. Next place is in the T'stat housing.
