kghost
Silver Medal Contributor
"The middle runner on a v8 int
"The middle runner on a v8 intake is between 2 exhaust ports and is typically hot! That is where the choke bymetal spring is located on the older mechanical choke systems.
Wrong location to be looking at temps.
look at the location that the sending unit is located.
If you have a lot of air in the incomming water supply you have to remove the lower unit from the outdrive to look at the water pump impeller and housing condition.
If you do, Take some pictures and post."
