No, the lifting eye is not the give away.
R drives had the lifting ring also.
TR and TRS is NOT your drive they are F'n huge....pre Bravo and direct drive no shifting, they use a transmission behind the motor like an inboard.
Because yours is a 1982 boat then the drive would be late 1981 or 1982 depending on build date.
So it is a 228 drive based on the 228 motor, not sure if it is a MC 1 or R.
The only way to tell would be the lower gear housing vertical driveshaft bearing cage. in the older drives, pre alpha they used 13 rollers, r, mr and alpha's used 18 rollers. Also the water pump base and I think the housing are different. Definitely the water pump base.
If I remember correctly..............
so if you lower is an MR or Alpha the current water pump housing and base is ALPHA 1 GEN 1 style.
MR and Alpha lower drives assemble different, the vertical drive shaft bearing is held in place by a retaining nut under the water pump base.
R drives and earlier models there is no retainer under water pump base.
So there are some identifiers
It is not as simple as saying it is one drive or another based on its looks............
And there are other identifiers also
So you may have a MC-1 or R upper and a MR or Alpha lower.........
Having the alpha/MR lower is better. Better lower drive. parts are readily available.
