Hello everyone,
I need your help for my Mercruiser V8 5.7 L 350 (2001) + base Bravo 3.
In the neutral position, idle of my engine is correct (about 900 rpm), ignition is properly seated (about 10 °), the acceleration is linear.
In summary in neutral the engine runs perfectly.
However when I switched the forward (or backward), the engine immediately loses about 200tours/min to reach 700tours/min. When I accelerate, it is on the verge of stalling. I have to accelerate very slowly or giving small jolts to avoid stalling.
Where this can come?
Otherwise in navigation, once past the 1000 rpm everything works correctly. this problem is present at idle in forward or reverse. For maneuvering is really not practical, in addition to maneuver you have to play with the engine so it does not shutdown...
Thank you for your help.
Sorry for my bad English
