"I have an 87 Cobia with a Mer
"I have an 87 Cobia with a Mercruiser I/O on it. 4-5 years ago I could run all day then pull the plug on the ramp and barely get a drop of water out of the boat. Now there is always water in it and I have to run the bilge often.
Last summer discoverd a leak in the drive shaft bellows right after the coupler went out. I had the shifter boot replaced at the same time. I thought having them repaired would stop the leak as well but it didn't.
I've tried to look for where the water is coming in repeatedly, but can see nothing. I've inspected the hull and everyplace that a screw or bolt goes through the hull at or below the water line, all appear to be okay.
One more thing that might be the key. It seems that a couple of times when I have had the boat beached with the lower unit down to help keep the boat from getting pushed to far up on shore. The boat has filled up very rapidly with water, almost to the deck in less than an hour. That is why I suspect it has something to do with the stern drive. The question is what?
I hope someone can help this thing is making me crazy!
Wingman"
Wingman"
