C
Chris Chapman
Guest
I have a 1987 Fourwinns 185 Su
I have a 1987 Fourwinns 185 Sundowner. I took the boat out the other day and was cruising at 35 mph and all the sudden the outdrive gave away. The motor was still running fine but out of nowhere it sounded like the prop fell off. No initial noises everything was running great. After stopping and raising up the outdrive i saw that the prop was not spinning at all when in gear (foward or reverse). The nut on the end of the prop was tight and the prop still spins. I checked to see if the prop was stripped out which it is not. I have no clue where to go from here any help would be great.
