91bayliner
I am replacing my the impeller on a Mercruiser Alpha One and have a question about the shifter shaft. I pulled the lower unit and was able to get the impeller replaced without any issues. However I am working on getting the lower unit mounted back up and am having difficulties with the shifter shaft. The shaft is just hanging from the upper unit and need to be pushed back up to reseat, however I am not able to hold the shaft up while re mounting the lower unit... So my question is should the shifter shaft be hanging like this or do I have an issue there that needs to be addressed. If this is normal, how do I get shaft to stay up while I am installing the lower unit..?
