"My Bayliner 2450 w/ Mercrusie
"My Bayliner 2450 w/ Mercrusier 5L and Alha one outdrive is overheating. The engine is sea water cooled. I tested the outdrive pump before launching w/earmuffs and it seemed fine.
Now that the boat is in the water, the engine overheats after 5 minutes running.
I removed some sea water hoses and found there is no water in the system.
I don't know why but I also have a sea water inlet in the hull as well as the outdrive.
I was told the sea water belt driven pump on the starboard side of the engine is probably bad.
Do I actually need to have the engine pulled to repair/replace the pump??
How can I remove this pump while still in the Hull"
