"Hi,
I have twin 4.3L mercr
"Hi,
I have twin 4.3L mercruisers. One is in the trailer position, and I can't get it down.
So far I've replaced both solenoids, cleaned all the contacts, checked there is power to the busbar. Last check was to remove the blue/white wire from the up solenoid and hit the trim switch. According to Clymer if the trim motor runs, then it's a wiring harness problem. I got no motor run, so presume the problem is not in the harness. I don't think the limit switch is adjusted incorrectly since it's been OK to now, and hasn't been touched.
Also I have twin controls, and neither set works, which I guess rules out a faulty switch.
At this point I'm lost, so any advice would be welcome, thanks."
"Hi,
