I have a 2001 mercruiser 7.4l
I have a 2001 mercruiser 7.4l w/ a bravo 1 out drive. It has a bad vibration on sharp turns and when you trim it up. I replaced the engine coupler with a new one and replaced the gimbal bearing. The u-joints are fine I also sent the prop out to be checked and it’s fine. The prop shaft is not bent. This all started after I hit something in the water. If you have any suggestions please let me know. Thank you!!
