I got a Mercruiser 7.4 that i have been servicing for 6 years, and they hydro locked the engine and busted a rod and slung it through the block. I installed a new engine and went to fire it up for the first time and it wasnt getting no fire. i put a new cap, rotor, and coil on with the new engine. It has 12 volts on purple wire going to coil when its not hooked up, when i go to hook it up it arcs bad like its shorting out and drops to 8 volts. I called the other merc tech i use to work with and me and him both said it sounds like a bad coil. I bypassed the safety switch, tried another new coil but nothing. i hooked a spark checker straight to the coil and grounded it and it will spark for a split second when you first start to turn it over then lose it. I need some help i gotta get this boat turned and out of the shop.
