Mercruiser 57 valve adjustment
A
agata
Guest
Does anyone know how to adjust
Does anyone know how to adjust valve for 2001 mercruiser?
I need to find out how to adju
I need to find out how to adjust the valve for the 2001 mercruiser 5.7. Can you help me?
"Ayuh,....
At Idle,..
Loos
"Ayuh,....
At Idle,..
Loosen 1 til it Rattles,...
Then tighten it til it Quites,+ 1/2-3/4 turn...."
"The instructions bondo gave a
"The instructions bondo gave are for hydraulic lifters. There are clips you can buy that keep oil from going everywhere, btw.
Unless you've had it appart, I would ask "why" they need adjustment though."
The correct way to do it is to
The correct way to do it is to remove the covers and leave engine off. Turn the engine until the cylinder you want to adjust is at top dead center(both valves closed). Then you tighten both valves down to specs(see manual) and loosen them a certain amount of turns. Then repeat for each cylinder.
"Ayuh,...
Actually,...
Bot
"Ayuh,...
Actually,...
Both ways are Correct,....
1 is Static setting of the valves,..
And,..
The other is the Dynamic setting of the valves....
I prefer the Dynamic method....
I've seen Too many valves set Way tooo Tight using the Static method..."
""I prefer the Dynamic met
""I prefer the Dynamic method....
It works fine if you follow the book. And by the way, I misspoke, you tighten til they touch and then TIGHTEN a predetermined number of turns."
"Ayuh,...
I set'em that
"Ayuh,...
I set'em that way on a rebuild,+ Dynamically reset'em after run-in....
Trouble is,...
Some of those Books say to tighten until resistence is felt,....
To a gumball fingered Non-Mechanic,....
That means the lifters are nearly Collapsed by the time the motor is 1st Lit....
Good video.
Covers it nicely.
Good video.
Covers it nicely.
Sure would be nice to work on a nice clean engine like that once in a while!
Rod
