"Hi everyone I have a 1990 Bay
"Hi everyone I have a 1990 Bayliner with a 5.7 bought the boat with a bad engine.Replaced engine with a recondition 5.7.The engine has no power at all.I have replaced spark plugs,wires,cap it has a new pickup in distributer and rotor button.It has a rebuilt carb and a new fuel pump.I put a new set of manifolds on it and it still has no power.I checked the timeing and it is dead on 8 deg btdc.I installed a new thermastat because it seemed to be running hotter than it should.So this is my problem.It will start and idle and run fine on the trailer.When i put it on the water it will run to about 1000 rpm when you go to w/o/t it has no power starts to miss and run real bad.When you back off on the throttle it will run badly and die.Then it is real hard to restart.I would be greatfull to anyone and everyone for there advice.Thank You!!!!!!"
