I have a 5.0 Mercruiser Alpha
I have a 5.0 Mercruiser Alpha One engine that dies out a couple of times a day when running the boat. You can be running 30 mph and the boat will start choking down and cut off. It will crank right back up. It doesn't appear to be an electrical problem because it doesn't shut off completely. It chokes down. I have had the dealer look at it and they can't find anything wrong with it. I got some fuel additive to see if that helps. Any thoughts on what might be causing the engine to die?
Scott
Scott
