Mercruiser 5.7 carb version.
Goodafternoon,
Our mercruiser 5.7 L V8 wont start, it seems to me it wont get any spark to start. It cranks the engine around but no spark. Whe changed the wires and bougies. And whe changed also the oil pressure sensor, and switch to the fuel pump. But now it wont start. Just cranking the engine but no spark
TB ignition troubleshooting guide is in this thread Post #4. If it is a 2001 it is probably the TBV not 4 but troubleshooting is the same
if you need a module can find them used on Ebay normally. The module is the expensive part... if its the sensor in the distributor that is not bad cost wise.
Not sure if it says to in the troubleshooting guide disconnect the shift interrupt switch if it is an alpha drive. if switch goes bad or is triggering it will kill the ignition
