Hi there,
I'm a newbie here and I have a 5.0 V8 305 carb and just took it out for the first time this summer. I started it up out of the water to warm it up for about 15mins and everything seemed fine. Got it in the water and was cruising around at about 35-40mph for a little while and then when I slowed down I noticed that something didn't sound right with the engine and it eventually died.
It started back up after a few tries, but when I put the throttle in gear it didn't start going like usual. It started to sputter and died again. I was able to restart and push the throttle forward much further than usual, it sputtered a little, but then finally kicked in and took off. It would run fine at a higher RPM for the rest of the day, but would run rough at idle or eventual die.
I'm assuming this might a fuel filter or carb issue. Not sure exactly where to start, but would appreciate any help.
Thanks,
Todd
Thanks,
Todd
