"This has probably been answer
"This has probably been answered already, but here goes. I bought this boat about a month ago not running. I'll try to be short with isues I've found since. After getting the motor to finally start I found the bellows ripped. Replaced bellows and gimble bearing. Then replaced starter. After all of this had a radiator hose blow due to over heating. Found the therostat was staying closed(replaced with 160 d ). Then overflow canistor was draining through overflow hose. Found closed system was empty. During this process temp never went over 150 d and overflow looked like boiling water and the overflow cap kept blowing off. The heat exchanger was cool on intake side and warm on exhaust side. The manifolds were extremely hot. So I pulled the thermostat out to see if that was the problem, but still overheated.Now my oil looks milky in crankcase and inside valve cover. Any help would greatly be apprecciated in helping me solve this issue. Could the head gasket have blown and caused all of this?"
