Phantomsculler
Hi. I have a 470 with a MR outdrive. The manual that I have indicates that the U joint drive gear nut should be torqued to 70 - 80 lbs. (My drive shaft has the large and small spacers between the bearings so I understand I do not have to use the rolling torque method of tightening). Can anyone narrow down the torque that I should use or should anywhere between 70 and 80 lbs be OK? Most torque settings that I come across don't give a range.
