Hello all, I have a Mercruiser 470 in a 1989 cuddy and a few questions about the carb I have. First off, I have completely rebuilt the engine and nearly everything else as well. I have the 2 barrel carb on it and I also installed the pertronix ignition module. The issue I have seems to be a very high idle. I have rebuilt the carb but I have never ever had the boat in the water. Today, I actually had the engine idle around 600rpms, but then when I went to adjust the timing to 8 degrees the engine revved up to over 2000 rpm. Not sure why that would of happened but it did. I have adjusted the throttle cable and I also set the choke to what I believe is correct but nothing seems to be working. Am I missing something simple that maybe someone has encountered? So far, it's been difficult for me to make a move on throttle and see what the carb response is since I've been doing this alone. I'm not new to engine building or carb adjustmenta but I am rusty with this since fuel injection has taken over. This is my first boat and it's been a 5 year rebuild. So I have a $10,000 refurbished boat that's worth $2500 lol
