Mercruiser 454 RPM
ronbeckson
"I have 454 Horizon,the rpms g
"I have 454 Horizon,the rpms go up and down between 1000 & 1300 in a looping action,under 1000& over 1300 are fine.Anyone know whats wrong?"
What year? MPI? Maybe might
What year? MPI? Maybe might be computer temp. sender or IAC motor gummed up.
The coolant temp. sensor is on
The coolant temp. sensor is on the T'stat hsg. The hsg. gasket has two small continuity buttons in it to complete the eletrical circuit ground. If it is corroded that could be part of the problem. Does the temp gauge read correctly all the time?
Cleaning the throttle body (TB) bore and thottle plate will improve idle. Use THROTTLE BODY CLEANER and not carb cleaner. Check all the electrial connections on the TB.
Try cleaning the TB. Test the
Try cleaning the TB. Test the TPS (Throttle Position Sensor) w/a digital VM for a dead spot.
