I have coolant leaking past the block off gasket, is it advisable to remove, clean up and install new gaskets ?
Block off gasket at elbow to manifold connection, which one to use ?
Green one's, as I understand it use no sealants ? Aviation gasket sealer / Permatex - 2. New parts only?
Graphite one's by Quiksilver, don't know much about them.
Stainless steel block off plate between two gaskets, is this an outdated method ?
Thank you
Thank you
