Mercruiser 43 stalls
coomablue
"hi. i have a problem when cha
"hi. i have a problem when changing forward to reverse or visa versa, engine cuts out, any info appreciated, thanks."
you prob need a new shift cabl
you prob need a new shift cable.but you can try and bring your idle rpms up that might help.
"Wyndam, Keith may be right, h
"Wyndam, Keith may be right, however, it may be something else. The Alpha drives (and others) have an ignition cut out switch which kills the ignition for a 1/2 sec when you are shifting. Does the ignition die when you are out of the water running on the hose? If not,it is likely the switch. If you look on the motor (port side, front) you will see where the upper (or fromt)shift cable enters a fitting that connects it to the lower shift cable. Look for the microswitch and see if the spring loaded yoke sticks up or down for a second, when you are shifting."
I think i may have a cracked w
I think i may have a cracked water jacket. Can I replace the block with a automotive block or do I have to go with a marine block..........john
"Keith. I can't up the idl
"Keith. I can't up the idle but i will look into the cable. Chris mentioned the cut out switch, ill check it out also this week end, Thanks."
