Hey all !
New member here. Long time boat owner, new to I/O boats always had outboards. We bought a 2006 Bryant 190 with the mercruiser 4.3 with 240hrs. Has an Alpha one gen 2. Really clean boat that’s been kept inside. The motor runs great, me and my son changed the oil and the fuel filter last weekend. The port elbow is running 60-70 degrees higher than starboard. Port elbow staying around 160 and starboard around 100 Verified with temp gun. Temp gauge on dash stays between 160-175 depending on how hard it’s being run. Any suggestions on what might be going on? I’ve ordered a new water pump kit and a circulating pump and thermostat, also have ordered plugs and wires. Just want to go thru it so I know what I’ve got. Would a failing water pump cause one side to run hot ? Also way less water coming out of port exhaust at transom. The only service records I have are new LU installed in 2016 and gimble bearing and bellows replaced at same time, and yearly oil changes. We also got A new battery and the alternator is putting out around 14 volts.
Thanks Michael.
Thanks Michael.
