Very baffling. I went to start motor one day and the starter continued to run after motor was started. I immediately shut off motor but starter continued to crank until I shut off the battery switch. Upon turning the switch back on, after about 3 seconds the starter would crank on its own again. Even with key out and in the off position.
I tested and eventually replaced ignition switch. With either switch completely out and disconnected it still cranked.
Thinking it was a bad or stuck solenoid, I removed starter and bench tested it. It worked as it should.
With starter removed, I then hooked a test light to the yellow/red start wire and it showed power within 3 seconds of turning battery switch on.
I traced yellow/red wire to a relay on top of motor...thinking Ahah, I found the problem...nope swapping out adjacent trim or fuel pump relay causes same issue.
I could find no issue with the ignition switch or wiring. It cranks even when the ignition switch is completely removed from boat and wires isolated. All harnesses and battery connections were pulled and show no sign of corrosion. Everything else works as it should and the motor will start but starter will continue to crank anytime the battery switch is on.
Is it possible the ECM/PCM is somehow at fault. I cannot figure any other way the yellow/red wire to starter solenoid is becoming energized. Furthermore, it is not immediate starter engagement, it is always after several seconds I hear the starter relay click and then the starter engages.
Any ideas or suggestions would be appreciated. Nearest Mercruiser dealer is about 140 miles away, so I am trying to avoid that.
Mercruise 350 MPI, Horizon 2007
