I have a 2006 Crownline 240EX with a 350 Mag MPI and a Bravo III drive. I noticed gas was spraying out around where the fuel line comes from the fuel cooling module ( the box that has the water lines and pressure pumps and filter in it). It was spraying where the stainless tipped hose end goes into that block and is held in place by a set screw. I put a new rubber quad ring on the stainless gas line but didn't help. It feels loose even after I tighten it good. I can move the hose and make it spray more and less. The stainless is not cracked. Any ideas?
More likely to be a hose or cooling block?
Thanks a bunch?
Thanks a bunch?
