tim_horton
"I AM HAVING PROBLEMS STARTING
"I AM HAVING PROBLEMS STARTING 3.0 AFTER A WARM ENGINE SETS A SHORT WHILE! I JUST INSTALLED A CARB
KIT (MERCARB) I HAVE CHECKED THE FLOAT LEVEL AND ITS OK. TO START THE ENGINE YOU MUST GO TO WOT
& GRIND ON IT FOR SERVRAL REVALUTIONS AFTER STARTED RUNS FINE, IDLES FINE, AND ACCELERATS FINE.
ALSO INSTALLED A WATER SEPARATOR IN LINE BEFORE THE FUEL PUMP IT HAS A SET OF PORTS TO USE LEFT SIDE OR RIGHT SIDE IN MY SET UP I USED (IN) PORT
ON ONE SIDE AND USED THE (OUT) PORT ON THE OTHER SIDE
ANY SUGGESTIONS
THANKS"
ANY SUGGESTIONS
THANKS"
