"1993 Mercruiser S/N OF15114
Bought used. Runs a while (10 minutes) then dies. Will start reluctantly after sitting a few minutes. Compression, great. Power, great. Assumed fuel problem, fuel pump strainer pretty dirty, serviced carb strainer, no change. Took entire ignition system off of a good running 3 liter. No change. Installed fuel pressure gage in the vertical line from the fuel pump to the carb. 6 psi all of the time.
So!! The carb may be running dry if there is a float in it. Assume there is but i am a diesel guy. Is there such a thing as a carb rebuild kit or i can just take the carb all apart and blow everything out?
Any other ideas?
Thank you very much. First Mercruiser, lots of Mercury outboards."
Any other ideas?
