Redrider6604
Last fall I picked up a boat in a trade. 1987 cheetah with the 3.0. Interior was shot and needs to be done which I do that for a living so that’s why I got it. Engine runs great and so forth. I noticed when fist running it, it had water leaking from the back of the engine. So pulled the motor out and replaced the welch plug behind the flywheel. When I had the plug out which it was rusted , I flushed the engine with a water hose. After putting the flywheel back on, went to drain the oil and it seemed like 3 gallons of water and oil pouring out. Anyways, I installed the engine back in the boat so I could do some tests. I’ve only ran it on muffs and haven’t put it in the water because it needs bellows. I run it every couple of days and oil level never changes. I have changed the oil multiple times just to see and it keeps looking like coffee with creamer in it. Pulled all the plugs and compression is 160-163 on all four with wot. Did a leak down test and that passed. Have done a smoke test on the cooling system for about 4 hours and never had a leak. That was with oil cap off, drain plug out, dip stick out, oil filter off and the lifer/ push rod plate off and the machine maxes out with pressure which shows no leaks. I made a complete block off plate for the exhaust riser and left the exhaust hole open just to see if smoke would come out of the exhaust but I’m getting nothing. Would appreciate if someone can guide me in the right direction.
