Hi Guys
When replacing a 3.0 liter Mercruiser timing gear cover do you use a dummy tool in place of the balancer to center the cover? I think I may put the balancer on then tighten the bolts I can access, pull the balancer off real quick and tighten the remaining bolts. I only have a short period of time to do this as I will likely be using Permatex's The Right Stuff. Is this necessary or is it overkill ? Any thoughts would be appreciated.
Thanks in advance
Jon Allen
Thanks in advance
Jon Allen
