Hey everyone, I have a 2001 bay liner with a mercruiser 3.0. Engine is a remanufactured motor installed in 2017. On my 2nd trip this year I noticed oil in the bilge being pushed out through the dipstick. Seems like slot of blow by coming from oil cap as well. Compression test reads 165psi on all cylinders cold. I haven’t done a leak down test because I don’t know how to spin the motor manually to get piston to TDC on compression stroke. The crank pulley is blocked by the motor mount and the water pump and alternator pulleys do not have enough grip with the belt to turn the engine. Is my only option to try and bump it to the correct spot with the starter or is there another way? I’m replacing the pcv valve and hose with something bigger to try and relive the pressure and stop oil leak, but I’m worried it won’t be enough and I’d like to know the internal condition of my motor. Any advice is appreciated.
