J
Johnathn Clayton
Guest
"I have a 1984 Mercrusier 260
"I have a 1984 Mercrusier 260 (5.7) with an alpha One drive. The boat hasn't been on the water yet this year. I've replaced almost every engine accessory because the boat has sat for 3 years: carb, distributer, coil, wires, plugs, fuel pump, water pump, temp sensor, power steering cooler, thermostat and alternator. I also put on a rebuilt lower gear housing and installed new bellows this spring. The problem is I think it's overheating. The temp gauge gets to about 160 and then will shoot up to 200 in a few seconds. I immediately turn it off. This is with muffs or submerged in a large plastic container of water. When I take the water inlet hose off the thermostat block and leave it unhooked and start the motor no water comes out of it. Shouldn't the stern-drive pump be pushing water out that hose to feed the cooling system? With the motor running water pours out of the propeller but not out of the two exhaust(?) holes on the bottom of the transom. This morning I removed the lower gear housing and checked the impeller and water pump, it appeared fine. It was new with the rebuilt lower gear housing. With the lower gear housing still off I took the garden hose and back flushed the water inlet line and water poured out of the upper gear housing onto the ground. So the path from the water pump to the thermostat is clear. Then I turned the garden hose around and flushed out the engine/manifolds then water eventually came out the 2 little holes on the bottom of the transom. So I know there is nothing stopping the flow through the cooling system and that everything appears to be hooked up correctly.
All I can figure is for some reason the sterndrive water pump isn't working but I have no idea why. With the lower housing off and the top of the water pump removed I can see that the impeller turns with the drive shaft. The key is installed in it. Is it possible the rebuilt lower gear housing had the wrong water pump installed in it? I've read something about a "pre-load pin" on the drive shaft is different than No pre-load pin. Mine has a little hole at the top of the shaft but no pin. Could this have anything do do with it? What am I missing? Thanks.
Johnathn Clayton"
Johnathn Clayton"
