Hello everyone,
Since last year, I've been struggling with an overheating issue on my MerCruiser 228 V8 (5.0 liter). During one trip, the engine suddenly overheated—90°C (194°F)—without any prior warning. Since then, the problem keeps recurring.
Best regards,
Jean
Parts that have already been checked or replaced:
- Thermostat
- Impeller
- Both exhaust manifolds (risers)
- Port side exhaust
- Water pump
What the mechanic did:
Since I was out of ideas, I brought the boat to a mechanic. He:- Removed both port and starboard exhaust systems
- Flushed all cooling passages with acid
- Also flushed the engine block with acid
- Performed a test run and said everything was fine—no overheating
Real-world test:
Yesterday, I launched the boat again. Result:- The engine overheated again
- It happened more slowly than before, but:
- During extended cruising at around 3000 RPM, the temperature climbs steadily
- If I briefly reduce throttle and then accelerate again, the temperature suddenly drops
My thoughts & question:
I'm at a loss. The cooling system seems clean, yet the issue persists. Does anyone have an idea what else could be causing this? Possibly:- Air in the cooling system?
- Faulty thermostat (even though replaced)?
- Blockage inside the engine block?
- Vacuum issue or backpressure in the exhaust?
Best regards,
Jean
