Mercruiser 228 - intake manifold gasket
Barney96
Do l use the rubber gaskets for the ends as supplied by the supplier or would l use a silicone sealer- with no rubber gaskets
Thank you for your time
Black RTV , clean the block, place a generous bead, set manifold in place, start and SNUG the bolts, let cure then torque/tighten all the bolts. This prevents you from squishing out the sealant and provides a better seal
Ayuh,.... This is what I do too,..... except I finger tighten the bolts, til the RTV cures,.....
