I'm looking at buying a 24 foot 2004 deckboat with a Mercruiser 5.0 Bravo 3 (260 HP) that has 715 hours on it. The compression test results were as follows: 141, 149, 131, 135, 127, 149, 133, 137. The percentage difference is 15% between the highest (149) and the lowest (127). The engine starts and runs well, with no oil smoke. I've gotten varying opinions on whether I should be concerned. One mechanic suggested that conventional wisdom was that any difference more than 10% should raise a concern. Another mechanic said that the 10% rule make sense for 2-4 cylinder outboards, but for a V8 auto-type engine, 15% was good, and up to 30% was acceptable (I checked the mercruiser service manual, it states that compression should be within 30% or more intensive maintenance should be performed). I'm looking for some additional advice as to whether 10% is the best rule of thumb for V8's, or 15% for a newer boat with 700+ hours is acceptable, and why? Thanks! Chad
