jimnlouisiana
"What is the correct PSI for t
"What is the correct PSI for the water pressure from the impeller. I have two Mercruiser 454 inboards. One side says 46.3 PSI at idle or throttled up. The other reads lower, like 5 psi at idle and maybe 25 psi at cruise. I changed sensor on the one that reads low and it still reads the same. Temps are normal on both."
