tomonthelam
I took on a restoration project of a 1986 ChrisCraft Cavalier with Mercruiser 200 Powerplant and Alpha Drive. This is the GM 305 engine with the 2BBL carb on top.
The boat sat idle with just 500 hours on it for nearly 18 years after my father in law passed on. He purchased it new.
Two years ago, the restore was complete and we ran it on a couple of test outings without any major issues. It sat idle for another two years as we are in So Cal and the drought has dried up most of our opportunities of using it.
This summer, we took the boat to Lake Tahoe, and after a few altitude adjustments and a new prop, had it running just like in the days when my FIL used to take it there.
However, after about an hour of moderate running, it backfires, looses power. I pull the throttle back to idle, and everything seems fine. This progressively gets worse (happens more frequently, and at progressively lower RPM) as we attempt to navigate half the lake back to the marina. By the time we get to the marina, I can barely keep it at 1200 RPM for more than 30 seconds. It does not stall, but if I turn if off, will start immediately (fearing vapor lock).
It felt like fuel starvation, and after asking many about the problem, the consensus was replace the 2 year old fuel pump, fuel filter, water separator. This was done, and we tried again. The boat would pull a skier (me), my daughter on a tube, and have no problem getting up on plane, just like old times. By this time we are two full tanks of fresh gas through the system, always using a preservative.
This weekend, after the new pump was installed, it happened again. Same exact symptom. Parked the boat, went out the next morning and repeated the same experience.
One other note: The carb was replaced this season as the original Merc carb was leaking badly and need a rebuild. The replacement was not a Merc carb, more like a stock automotive carb. It was supplied by a local marine shop.
I'm looking for any hints as to what may be the problem, the Carb???. The Merc carb is now getting a rebuild with high altitude jetting, but it will be a couple of weeks before we return to Lake Tahoe to test it.
Everything else in the fuel system was replaced two years ago, and the tank was removed and cleaned.
Any intelligence on this matter would be appreciated!
