"Ok this is bizarre. The one M
"Ok this is bizarre. The one Marine mechanic I told this to thought I lost my mind. I finally got my boat out for the summer, and after many hours trying to get it to idle right adjusting carb and timing, only to discover a dead cylander due to a bad plug wire, I finally got it on the lake. The boat was running great, all kinds of power, and great acceleration out of the hole, the timing must have been spot on for once.
I got down to the end of the lake near the dam and started to turn, and the engine just stops. The momentum of the engine keeps it spinning, but the ignition just stops. It is weird hearing an engine decelerate from 4500 without any combustion. Then of course it is a hard start again, probably because it gets flooded out with the Carb being still WOT and no spark. The weird part is that it is only in turns, and not super hard turns, just a gentle turn will do it. If I am really super gradual in a turn I can keep it from happening. Probably something to do with the throttle linkage and the cut out switch perhaps? Not sure why it would only do it when cornering though. Doesn't matter which direction I turn. The other weird thing is that even if I straighten it out while the engine is stilling spinning ignition does not return. I am considering possibly water in the fuel and the turning causing a water layer in the tanks to be picked up instead of fuel?
It does not seem as if the sterndrive is binding, though it could probably use an overhaul.
Thank you for any ideas"
