Mercruiser 130 running without drive attached
gkm24
Is it ok to run my mercruiser 130 2004 without the drive attached if I connect the hose pipe to the water intake on the transom?
I have a leak somewhere but the bellows and shift cable look to be fine. I'm not sure if its coming in through the seal from the riser to the exhaust, so I just want to check before I change the bellows on the drive and shift cable which were changed last year!!
Thanks for any advice.
