Mercruiser 1
dcso
any service pointer for servic
any service pointer for servicing an mr1 drive. looking at it i have to remove the bottom pin on the bell housing then loosen the two bolt on the top to remove the bell housing to get at the boots?
thanks
ted
"thanks,
i have another probl
"thanks,
i have another problem, i can't get the ss coter pin out of the bottom hing pin, i may have to drill a hole through assembly to knock pin out, i'm going to let soak over night and see if it will loosen
thanks
ted"
"You dont remove it to do the
"You dont remove it to do the boots,
Even it you could remove the 2 bolts the steering arm would have to be removed and the square pin removed first."
