Procedure for removal and installation of short shift cable.
1. Remove out drive from gimbal housing by putting shift control into forward gear first.
2. Use bolt cutters and cut old cable at bellows.
3. Pull large grey aluminum shift cable end out of inner core
4. Use new tool and remove threaded cable end
5. Inside at motor, remove cable end from shift bracket
6. LOOK CLOSELY AT SHIFT CABLE ROUTING THIS IS VERY IMPORTANT. Take pictures if needed.
7. Pull cable thru transom/bellows and discard.
8. New kit will contain inner core, outer core, plastic cable end, two pinch screws and small pinch tube which screws thread into, large aluminum cable end, set screw, safety wire, small plastic piece for transom (throw away), threaded cable end (tube with lock nut) and possibly bellows if not order one and replace it while doing this.
9. Take OUTER CORE and feed thru gimbal housing threaded cable hole, wet bellows small end with dish soap, feed cable end thru bellows then push bellows toward gimbal housing while feeding cable thru hole in transom assembly and feed it/route it the same location/path as original. Once this has been accomplished start to thread cable into gimbal housing. It is best to have a second person in the boat with their hands on the cable end. While tightening the cable into the Gimbal housing have the other person slowly help by twisting the cable (gently) while you tighten it. Tighten the cable end so the Hex is about two threads from bottoming out ~ 1mm or so. Once this is done now comes the cable assembly.
10. Now outside the boat in a clean area, take the large aluminum end, feed cable thru it. Once this is done install the set screw, tighten set screw until it makes contact with the cable end. Now install the safety wire thru the hole in the set screw and wrap around protrusion on large aluminum and. Start to twist the wire, while doing this it is very important that the aluminum part is free to rotate but with little or no forward or backward play with respect to the cable.
11. Twist the wire, cut to about 3/8 inches and bend in-between the set screw and protrusion. Done.
12. Now feed the inner cable assembly all the way thru the outer core and your friend should get it inside the boat. THERE SHOULD BE LITTLE RESISTANCE OTHER THAN THE BENDS IN THE OUTER CORE, if high resistance is felt be very care NOT to kink inner core at all and for that matter the outer core either!!!!
13. Once the cable is assembled to this point install the threaded cable end and lock nut into outer cable inside boat. This MUST be threaded in all the way it can go. Sometimes it is necessary to use pliers or something like that to make sure it is seated all the way. Once seated tighten lock nut to outer core.
14. Now take plastic cable end, also get the pinch tube with two pinch screws, start screws into tube but too deep so hole in center is clear, insert into plastic cable end, slide plastic cable end over inner core all the way so the inner core touches the plastic cable (you will see what I mean). Once this is done tighten pinch screws snugly. Now move cable to it approximate location and make sure it will fit into bracket without twisting. If you have to twist loosen pinch screws and relax the cable end to fit naturally. Once this is done tighten pinch screws securely. Tight is good, over tight is not.
15. Once this is done push cable end all the way in, and attempt to install the out drive back onto gimbal housing. This will be tough as you need three to four hands if not experienced. You must have the outdrive in forward gear, Small brass shift arm pointing straight ahead at 12:00 and the aluminum shift cable end sticking out so the shift shaft U shaped piece that aligns with the brass shift are in alignment. Not easy for the novice so be patient.
16. Once drive is installed and rams hooked up follow procedure from above.
17. The shift cable bellows, once done with adjustments and all, now raise drive up almost all the way, install bellows large end onto flange on transom assembly, tighten hose clamp. MAKE SURE YOU INSTALL HOSE CLAMP EXACTLY THE SAME LOCATION AS IT WAS WHEN YOU TOOK IT OFF!!!.
The bellows may be a bit tough to get on all the way. MAKE sure it is seated all the way around the flange!!!!! Then tighten hose clamp.
18. Now extend the small end of the bellows so that it is extended fully without stretching it. Once you have it extended use a TY-Wrap and out it on the small bellows end and secure and trim excess off making sure any sharp end is pointing away from large bellows above.
Now you should be done!! Good luck…
