"Thanks for the quick response
"Thanks for the quick response.
Maybe the Merc manual for this engine and carb is wrong. If you have access to the manual, The section on Fuel System, page 5C-10, has an exploded view of the carb, similar to the one in your link, which is also similar to the one from my Clymer Manual. However, in the Merc manual the spring is shown on the opposite side of the spring. Also, on page 5C-5, the procedure and illustration are clear that the spring goes in the carburetor body, and the filter goes open end to the filter nut.
Why could the manuals be opposite of one another? Was there a tech bulletin published by Merc after their manuals were printed?
I"m not trying to start a p'ing contest, I would just like to be sure. My reasoning is that if the spring goes against the bottom of the filter, it would ensure that the open end is always against the input opening. If it goes inside the spring, it might push the filter away from the opening, and allow contaminants into the carb.
Am I all wet? I know experience is worth a ton of book learning, so I would just like to understand why Merc is not the same.
Again, thanks very much for your response, and I do appreciate you taking the time to answer.
This boat is old, but it's fairly new to me, and it's like my baby, if you know what I mean.
Thanks again."
