B
bshaw
Guest
My 1986 SEARAY SUNDANCER 270 H
My 1986 SEARAY SUNDANCER 270 HAS TWIN MERC 170 4CYL ENGINES WITH SEALED COOLING SYS AND ALPHA 1 DRIVES. THE PORT SIDE ENGINE TEMP STEADILY CLIMBS WHEN ON PLANE OR HIGHER SPEEDS. IT'S FINE AT SLOWER SPEEDS. THE ENGINE IS NEW AND THE SAME PROBLEM OCCURED WITH THE OLD ENG. THE HEAT EXCHANGER WAS CHECKED AND CLEANED BY A RADIATOR SHOP. THE WATER PUMP IMPELLER WAS REPLACED WITH IN THE LAST COUPLE SEASONS AND SEEMS TO HAVE FLOW. I HAVE LOOKED FOR RESTRICTIONS BUT HAVE FOUND NONE AND MUST BE MISSING IT. HOW CAN I VERIFY GOOD WATER FLOW AT HIGH SPEED? ANY IDEAS?
FRUSTRATED
BRIAN
FRUSTRATED
BRIAN
