R
Ronnie Woodcock
Guest
" The motor stays cool below 2
" The motor stays cool below 2000 rpms but when I hammer on it, it will eventually get hot and I can see steam rolling off the pee stream. These are the things that I have already done. Put new water pump everything on it, impeller,housing,cup, plate,& gaskets.New pressure relief valve, Head gaskets,new thermostats I've ran it without the thermostats in it nothing changes. It will only give me 15 to 17 psi at wot. And barely reads 1 psi at idle. I've talked with several techs. around this area, does anyone have suggestions, I have ran out. Thanks "
