Hi,
I’m new to this forum and this is my first post.
I have a 2001 Mercury 115 4 stroke with a trim tilt problem, the problem is when under way at idle or just over I trim the motor up as you would for shallow water travel and the motor tilts up ok but does not stay up.
After releasing the trim button the motor then slips down to about 30 degrees that shows as the third or middle increment on the trim tilt gauge.
I’ve replace the manifold unit in the reservoir and the problem still occurs.
I am hoping someone on the forum might have had this problem and solved it and could give me some help.
Thanks in anticipation
Steve
Steve
