I have a 2002 optimax 150 hp.
I have a 2002 optimax 150 hp. I have a continuous alarm going off at different times. It seems to be an oil problem. I have replaced the whole reservoir under the cowl along with the switch mounted on it. I changed the fuel filter and I have cleaned checked all oil lines on the onboard tank. It seems like air pressure will build up in the onboard tank and when I vent the tank the alarm will stop. It’s a vent less system but what is holding back the flow and tripping the alarm. Thanks
