Yellowstreak
new boater here with no outboard experience needs troubleshooting help. i have a 1982 Merc 90hp inline 6, 2 stroke "tower of no power". the motor was strored for 10 years. fuel was drained and motor was fogged. stayed indoors all but 2 years and was covered when outdoors. first outing, it made power and ran well. took it out again to get trim settings dialed in (power T&T pump needs rebuilt) and could not get full power. it starts and idles good, but cannot get above 1800-2200 rpm in gear without bogging down and shutting off. backing out of throttle slowly will allow motor to stay running but never reaching a planing speed. fuel tank, fuel lines, seperator are new, pump rebuilt. i run 100% gas with 2.5oz/gal 2 stroke oil. ran seafoam through for 2 hours while cruising to no avail. bulb seems about right while running and pumping it while advancing it doesn't do much. removed discharge hose at pump and squeezed bubble. getting about 2 oz per squeeze of clean gas. pulled bowl covers off 3 carbs. not a spec of contamination or varnish -looked brand new inside. floats and linkage look good too. only filter i find is the screen on the pump and the seperator i installed. where to now? thakns for any advice.
