etiwandablues
Does anyone have a procedure or experience pressure checking a Bravo outdrive? Mine is a 96 Bravo III and has a remote oil reservoir. I just replaced the drive shaft housing due to a broken cavitation plate and now I have an oil leak. I found a good (visually) used replacement housing with the same part no & shim stampings and then swapped all the internals. I did change o rings, bellows, gear oil hose, & shift cable. I'm leaking a full reservoir about every 45 min of runtime, no or very little leakage when not running. No external evidence of leakage with the boat in the water, i'll pull it out tomorrow. I have some leakage in the bilge but not enough to account for all the oil I'm losing. I can't really get to or see the thru transom gear oil fitting in the engine compartment, too cramped. Any help woiuld be appreciated. Thanks
