"Have a 2004 SeaRay 215 Weeken
"Have a 2004 SeaRay 215 Weekender, 230 hours on the Merc Alpha 5.0 carb'd engine. It has (2) fully charged and properly connected Optima blue top batteries in it. The boat will start fine in the driveway when hooked up to the hose and muff. The last two times I took it down to the ramp and dunked it, it turns over and at times sounds like it wants to start but never does. I load it back on the trailer, take it home, and PRESTO - - it will start on the hose and muff. This leads me to believe its some type of grounding issue. I gave the engine a once over looking for any obvious loose wires and pushed the cabin fuse box tester to see if any fuses were bad. Nothing out of the ordinary. The terminal anode leads on the outdrive are secure, non-corroded, and all anodes are in place and in decent shape. IM AT A LOSS! Any thoughts/suggestions."
